NI MAX Tasks and Terminal Configuration
Hi All,
Gumby question here, but I've never spent much time setting up tasks before.
When I setup a NI-DAQmx Analog Input task in NI MAX, I don't see any way to set the terminal configuration to differential input. How does the system deal with terminal configuration if it is not specifically called out?
Thanks in advance.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,436 Views)
I assume you know about DAQmx, which has functions to do such things as set sampling parameters and configure inputs.  The Create Channel function, shown here, lets you configure the terminals (here as Differential) and also the A/D range (here 0 to 10 v).DAQmx Create ChannelDAQmx Create Channel
(3,427 Views)
Accepted by topic author diarmaede
Since you specifically asked about MAX, yes you can set the terminal configuration in it.
https://forums.ni.com/ni/attachments/ni/170/1126427/1/Capture.PNG
(3,387 Views)
Ah!  Okay.  I had the "Details" expanded on the channel settings field, so the Terminal Configuration options were not visible in NI MAX. Hey... it was late and I wasn't thinking clearly.
Thanks for the help!
Forbes Black
(3,317 Views)
