NI MAX Task Editing Disabled
I have a NI-DAQmx Task that when I select it under NI MAX, it displays following message, does any know why I don't get the task setting? Is this a special feature to prevent changing of the task setting, or something is corrupted? See image attached.
"Interactive editing has been disabled for this task"
(2,906 Views)
A programm or a VI that ran on your computer must have used the VI "DAQmx Save Task" to save a task to MAX so that it cannot altered interactively.
Regards, Jens
Kudos are welcome...
(2,889 Views)
Accepted by topic author JJZhang
Jens is probably right about the origin of your problem.
Workaround: 1) export your configuration in MAX in ".ini" format 2) delete the task in MAX, 3) edit the ".ini" file with a text editor and remove the line "AllowInteractiveEditing=0" 4) save the ".ini" file and reimport the configuration in MAX using this ".ini" edited file.
After a refresh in MAX, you should be able to edit the task.
Boris
(2,758 Views)
