NI MAX Remote Systems, Add/Remove software option is not working
Hello All,
While trying to upload the software through NI MAX using "Add/Remove software"option, We get the error as shown in the attached screenshot.
Error "Command is not supported by given protocol"
Kindly let us know your inputs to resolve this issue.
Durai S
(3,032 Views)
There is so much you aren't telling us.  Instead of a picture of the Error Message, a more useful picture would be of the MAX left pane showing:
  • The My Computer, Software Option, expanding all of the entries (it make take several screens).
  • The Remote Systems Option, showing all attached Remote Systems.
  • The Software Option for each of the Remote Systems.
Also tell us which version of LabVIEW (and whether 32 or 64 bit) you are trying to install.
(2,998 Views)
Hi Bob Schor,
Here is the full window attached.
we are using LabVIEW 2020 SP1.
Kindly let us know your inputs on this.
(2,971 Views)
Accepted by topic author Durai_Selvaraj
What is that Remote PC, a Pharlap ETS system or a NI Linux RT system?
Did you install the complete CompactRIO drivers?
If you use a Pharlap ETS realtime platform, you have likely a problem as the LabVIEW 2020 release removed support for cRIO based Pharlap ETS based targets, which as far as I know the desktop Pharlap ETS PC system also falls under. Support for Pharlap ETS based PXI systems is scheduled to be removed in the LabVIEW 2022 release too.
https://www.ni.com/content/dam/web/pdfs/phar-lap-rt-eol-roadmap.pdf
Unfortunatealy while you can technically create an NI Linux RT based Desktop system, this is legally not a sound idea since NI has not yet created a licensing solution that allows you to do that. You would be in legally dangerous waters if you tried to do that and use it in any way.
Rolf Kalbermatter  My Blog
(2,968 Views)
Well, you didn't actually expand the Software Tab for "My Computer", but you did say you were using LabVIEW 2020, which (as Rolf's reply makes clear) no longer supports using a PC as a Real-Time system since PharLap has reached "End-of-Life".  The Good News is that NI does make a variety of Real-Time Hardware that will support NI Linux Real-Time.
(2,950 Views)
