NI Library Icon problems in classes
LV2021 is the last one supporting PharLap OS. Anyone knows if there are any perspectives on getting a bugfix for LV21?
Message 11 of 16
(1,725 Views)
I haven't heard of any plans to patch this bug in 2021 SP1, but I have made LabVIEW R&D aware of this thread and your request.
Message 12 of 16
(1,720 Views)
Have been using the "Apply to all VIs" after editing a class icon quite a few times now in 23Q1 and have not run into this issue. So far 😁
~ Helping pave the path to long-term living and thriving in space. ~
Message 13 of 16
(1,664 Views)
Just as a quick hint for everybody keeping using LV2021. If you want to prevent the problem with VI Icon overriding with blank, rename a layer to a different name.
It seems as if renaming the layer name "VI Icon" to "VI Icon1" does the trick.
This unfortunately has to be done for each and every icon in the lib, but it can at least prevent some frustration when you have well designed icons and not only some text inside...
In my understanding this override happens to all VI Icons that only contain default layer names like "NI_Library" or "VI Icon". As soon as you drop a new layer (e.g. a glyph) this problem seems to disappear.
Message 14 of 16
(1,332 Views)
My technique to avoid icons resetting with LV2021 was to drop an instance of all the library members (VIs/controls) on a single diagram (like a VI "Tree"), which I kept open during the library icon modification. By doing this I never had my icons reset again.
Message 15 of 16
(1,323 Views)
Ha! That really seems to work! Thanks a lot, that is way faster than editing the layer names of each VI 😁
Message 16 of 16
(1,295 Views)
