NI Labview Write To Measurement File
Hi Folks
I think I found a bug or error on using Write To Measurement File of Labview, when I trying to datalog values less than 1mA, say (0.000999966) on the excel sheet it only reads on 0.001. even I change the Number format on the excel sheet, I still can't get the correct reading. anyone experienced it?
I know my codes are working since I can datalog the correct readings when multiply it by 1000 then input it on the "signal" of the WriteToMeasurement file.
(2,884 Views)
Can you show us some code with typical data?
(2,873 Views)
