NI Labview+ Suite 2024 Q3 64 Bit
Hello all,
I'm trying to install the NI Labview+ Suite 2024 Q3 64 Bit on my HP probook running on Windows 11 64 Bit. I'm using the full package manager that I downloaded from LabVIEW+ Suite-Download - NI. I can run through the install wizard, choose my package contents, agrree all neccessary agreements and the installation starts running. But then at some point it crashes with notification:
"A problem has occurred:
The network operation has exceeded the time limit specified by the user or system. (Operation too slow. Less than 30 bytes/sec transferred the last 60 seconds)"
I tested my download- and my upload speed on Speedmeter.de - Mit DSL Speedtest die echte Internetgeschwindigkeit messen. The result was 874.4 MBPS downstream and 951.1 MBPS upstream.
Are there any difficulties known on NI-Server side? Is there a offline installation package available?
Best wishes
Ollem
Message 1 of 1
(618 Views)
