NI-LabVIEW run-time engine interop 2010 failed to install
While installing Labview 2010 (32 bit) I got an error message:
NI-LabVIEW run-time engine interop 2010 installation has failed with the following error:
Error 1935. .... (see the .ppt for screenshot if interested)... HRESULT 0x8002802F
I googled HRESULT 0x8002802F and found a page that said that this error is usually b/c of a missing/corrupt entry in the registry: file %windir%\system32\mscoree.dll, and that "repairing the highest version of the .NET Framework on the system will correct any problems resulting from this error."
I have verified that mscoree.dll is not present, and I don't have the .NET Framework installed on my system. SO, I have the following questions:
1) do you concur with the advice given on the page referenced re: the reason for the error;
2) If so, should I install .NET Framework, and what do I then need to do in LabVIEW to tell it that the .dll is now present?
3) If your opinion is other, what do you advise?
Cheers
(3,452 Views)
Hi Luke,
After doing some research, there are two possible solutions.
1) According to a KB, it could be your antivirus. You may want to try to turn off any spyware blocking software such as Ad-Aware, Norton, etc and try the installation again.
2) Another customer had the same error, and they got it working by installing .NET 3.5 from Microsoft's website and then installing LabVIEW again.
Hope one of those options work for you!
(3,420 Views)
Thanks for the reply. I'll try that.
(3,418 Views)
