NI LabVIEW Run-Time Engine + TCP/IP
Hello, Anybody knows how to activate TCP/IP service on PC with standard NI LabView Run-Time Engine installed. If I trying communicate with server from my PC (LVRTE) its works correctly.   However, when I am trying interchange client and server applications it appears with error 1.  Probably I need to add some settings to *.ini files on PC with LVRTE? --- Alex
Message 1 of 9
(4,956 Views)
Are you referring to using the VI Server, or are you doing raw TCP/IP communication? If you're talking about using the VI Server, then I think you need to have these lines in your .ini file:
server.tcp.enabled=True
server.tcp.access="+localhost"
server.tcp.port=3362
Modify above as needed (e.g., for the access).
Message 2 of 9
(4,935 Views)
Client/Server applications are communicate via standard TCP/IP VIs. I have tried to add 3 line as you wrote to server.ini, but it's didn't help :mansad:
--Alex
Message 3 of 9
(4,921 Views)
In LabVIEW select options>>VI Server: configuration>>Check the TCP/IP option.
This has worked for me!!!Smiley Happy
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 4 of 9
(4,917 Views)
JK1, I have LabVIEW Run-Time Engine installed on PC with Server application. Smiley Wink
-- Alex
Message 5 of 9
(4,915 Views)
sorry dint notice that 'application' wordSmiley Tongue
But small suggestion: In LabVIEW environment >>Options>> VI:machine access>> add>*   to allow access to all machines.
Now create the exe.  Because when you create the exe the LabVIEW.ini file with current environment settings is added by default and the above command will add a line to ini file.
Just give a try if you havent triedSmiley Wink
With regards,
JK
Message 6 of 9
(4,897 Views)
If you're using the TCP/IP functions (TCP Read, TCP Write, etc) then none of these options in the .ini will fix your problem.  The options in the .ini file are only useful for enabling access to VI server, remote front panels, and the LabVIEW web server.  There's probably a mistake in your code that is causing this error.  What is the actual text of the error?  At which function does it occur?
Message 7 of 9
(4,889 Views)
As I indicated, the lines are only applicable to using the VI Server. You had not indicated whether you were using the VI Server or just the TCP/IP VIs. At this point we need a better explanation of what you're doing. Specifically:
  • What does this: "If I trying communicate with server from my PC (LVRTE) its works correctly." mean? What is the "server"? What's it running? What do you mean by your "PC (LVRTE)"?
  • What does this: "However, when I am trying interchange client and server applications it appears with error 1" mean? What is the "interchange client" and the "server applications". Reading this implies you have more than one application running on the "server", whatever that is.
Seeing some code wouldn't hurt either.
Message 8 of 9
(4,879 Views)
Hi Alex,
There is a KnowledgeBase article that talks about changing the port number so the different applications can communicate.  Does that help?
Bryan H.
Message 9 of 9
(4,850 Views)
