NI-GDS Error
I am using NI-GDS Version 1.1.87.94. And in my project, I always use EndevoGOOP400 as my class provider.
If I open LabVIEW without connecting network, the problem will be there:
When I right-click a class and select GOOP - Add Method...
The dialogue popup
But I can't find any file named GoopClassProviders.ini.
To solve this, I need to close LabVIEW, connect the network, launch LabVIEW again.
But if I connect the network when I load LabVIEW, it will take minutes to start, then each quick drop action (ctrl+ space then ctrl +t) takes me around 3 mins.
Just want to ask if anyone has the same problem? and is there any method to heal it?
Thank you.
Shu
Shu Yan
CLA since 2010 | CTA since 2012 | CLED since 2016
sjtuyan@gmail.com
Message 1 of 1
(1,077 Views)
