NI-Farm: Farm server is not responding
I'm using an example model in Labview 2014 (NI 9401 Digital Line Input and Output) with cRIO-9033. I've installed Xilinx tools (Xilinx 14.7 and Vivado 2013.4), Labview 2014 FPGA Module and Labview 2014 RT module on my PC. I've changed the target in labview project to cRIO-9033 device. The modules in cRIO are identified in labview and vi is copied in cRIO-9033 NI 9401 module. When I compile FPGA vi (Run or Build specifications) with local compile server, I obtain NI Farm error. Why am I receivinf "farm server not responding" problem?
Thank you in advance
(5,468 Views)
If I remember correctly you still need to configure your firewall even if you are compiling on a local server.
http://digital.ni.com/public.nsf/allkb/8473FD1983400E3F8625710D0055EB85
This paper suggests that is moved to 3582 but if you look at the white paper on configuring firewalls it still says FPGA compile server goes through 3580.  They are both a little outdated so I'm not sure which one is actually correct.
(5,428 Views)
