NI FPGA Compilation error
Hi ,
I am using NI Labview version 2010 SP1 ,Xilinx 11.5 compilation tool software  and i need to compile the FPGA code for NI 7851r FPGA,While i start compiltaion i am getting the error ("Error:sim 433 Could not find the selected IP. I attached the snap here.Kindly help us to fix this.
(3,297 Views)
Hi Jaffer,
It looks like you have all the right software installed for this compilation so I dont think that is the problem. Are you compiling your own code? Could you try a blank VI or an example for the 7851r? If the examples work then please post your project zipped together so I can view what may be going wrong. If you cannot compile a blank VI then please post a MAX technical report so I can confirm that you have all the software you need installed on the system.
MAX Tech Report:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019hceCAA&l=en-US
Patrick H | National Instruments | Software Engineer
(3,243 Views)
