NI-DAQmx
Seems a common problem in that I cant find NI-DAQmx in my Functions folder.
All I have under Measurement I/O is
Chased down the packages in NI Package Manager, tells me its all ok (obviously not!). Left my laptop doing a repair on it last night (takes forever) and still the same this morning.
I have previously wiped the machine clean and reinstalled NI so that didn't resolve it. Maybe that caused it?
Any help?
Message 1 of 8
(5,270 Views)
What's your LabVIEW version?
What version of DAQmx did you install?
Be aware that any DAQmx version will only support the 4 previous LabVIEW versions.
Regards, Jens
Kudos are welcome...
Message 2 of 8
(5,260 Views)
See screenshot from MAX
Steve
Message 3 of 8
(5,253 Views)
well, that should work, if you install LabVIEW 2020 first and after that DAQmx 20.7
Sorry, but I am at a loss now...
Regards, Jens
Message 4 of 8
(5,244 Views)
Hi Jens
In the process of uninstalling it all (again) and then install it in an order to hopefully work.
You would think that a big software company would be able to write an installer/package manager that would handle this for you 🙂
This will wipe out most of this mornings productivity waiting on it.
Cheers
Steve
Message 5 of 8
(5,240 Views)
Hi Steve,
if everything is correct the NI package manager should show a package "NI-DAQmx - support for LabVIEW xxxx" (or similar) under "installed package". That is at least how it is on my system (although I am still running only DAQmx 20.1).
Regards, Jens
Message 6 of 8
(5,198 Views)
Accepted by topic author ssoper
Hi Jens
Took the plunge and un-installed both NI-DAQmx and LabVIEW then reinstalled them.  Seems to have sorted it.
Cheers
Steve
Message 7 of 8
(5,194 Views)
I have LabVIEW 2017 and have installed NI-DAQmx 20.7. NI MAX is running correctly.
But I cant find NI-DAQmx under 'Hardware Input and Output' in 'Find examples'. Also, under installed in NI Package Manager, I cant find NI-DAQmx - support for LabVIEW 2017, as you have said(It is a little different).
I have attached the NI-DAQmx installed files. Could you tell me what might be the issue?
Message 8 of 8
(3,590 Views)
