NI-DAQ for USB-6008, LV 2012
Hello, I have a NI USB-6008 for which I want to create a VI with Labview 2012 for logging one channel at 0-2V from a current shunt. In the our previous version of Labview 2011 I was experimenting with DAQ Assistant which made the job easy, but in LV 2012 this doesn't seem to exist.
I was reading help files and I should be able to use NI-DAQmx but I can't seem to be able to find it. In NI Max I can see NI-DAQmx is there and can run  NI-DAQmx test panels on the USB-6008, but in LV 2012 I go to blank VI, block diagram, and I'm stuck. Any help will be greatly appreciated.
LV 2012
Windows XP
NI USB-6008
Message 1 of 9
(3,930 Views)
Hi there,
Can you check if you have DAQmx functions in Measurement I/O > NI-DAQmx in the function palette?
If no, did you re-install the DAQmx device driver together with LabVIEW 2012?
And what is your DAQmx version you're currently using?
- Ee Lim -
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
Message 2 of 9
(3,913 Views)
I don't see the NI-DAQmx where yours is. What do you mean specifically when you ask - did you re-install the DAQmx device driver together with LabVIEW 2012? I believe it was installed with LV 2011 but not re-installed after LV 2012 was installed. The verson of NI-DAQmx is 9.8, thanks!
Message 3 of 9
(3,870 Views)
You need to install DAQmx after installing LabVIEW.  Use the version of DAQmx that came with the newest version of LabVIEW.
Message 4 of 9
(3,860 Views)
You must install DAQmx after installing LabVIEW. You'll probably have to download a different version - one that is compatible with 2012.
Message 5 of 9
(3,859 Views)
Hi, I installed NI-DAQmx 9.4, still the same it is available in NI MAX, but can't find it in any palettte in LABVIEW 12. Is there anything else I can try? Here again is the setup:
Windows XP
Labview 11 and 12 base developement System and Appliocation Builder installed
Message 6 of 9
(3,818 Views)
Hello Doug,
NI-DAQmx 9.4 was released in August of 2011 and does not include support for LabVIEW 2012.  Refer to ni.com/downloads for an-up-to-date list of driver releases, you can find the DAQmx downloads here:
NI-DAQmx driver releases
http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3478.41.181.5495,s...
Tom L.
Message 7 of 9
(3,816 Views)
That's why I said to use the version of the drivers that came with the latest version of LabVIEW which is at least 9.5.5 according to NI-DAQ and LabVIEW Version Compatibility (for Windows)
Message 8 of 9
(3,813 Views)
Ok I completley re-installed LV 2012 and paid attention to what was being installed and .. Sucess! I can now avail of NI-DAQmx thanks everyone KUDOS for everybody!
Message 9 of 9
(3,800 Views)
