NI DAQ Assistant
Hi ,
I need to use DAQ Assistant for data aquisition from 3 different channels during 2 separate processes that happen one after the other in a while loop. i  did the daq programming and for the 2 processes i use 2 flat time sequences and i do not know how to enable the data aquisition during both of them. Can somebody help me?
Thanks in advance!
(4,002 Views)
I'd strongly advise you to read this excellent DAQmx White Paper and then stop using DAQ Assistant.
(3,994 Views)
I see, i will do that, however how can i have data aquisition during both processes if i use time sequence to separate them?
Thanks again
(3,985 Views)
I don't really understand what you want to do.  Do you want, for example, to acquire 100 points from Channel 1 at 1KHz, and when that is done, collect 200 points from Channel 2 at 2 KHz, etc., or (almost simultaneously) collect 100 * (a point from Channel 1 and then a point from Channel 2) at 1KHz, or (almost simultaneously) 100 points from Channel 1 at 1KHz + 200 points from Channel 2 at 2 KHz?  Give a better description of what you want to do and we can better suggest if/how to do it.
(3,976 Views)
Sorry, i will try to be more specific, so i need to aquire data from the 3 channels simultaneously, with the same rate and number of samples during discharging a battery (the dc load i use is also controlled in labview) and then during the rest period after discharging. So basically i want to discharge a battery for X minutes and then wait for Y minutes and so on up until a condition is verified and all this time i need to have data aquisition from the DAQ module.
Thanks again!
(3,952 Views)
Have you ever used MAX?  Open MAX (also called NI MAX, or Measurement and Automation Explorer) on a computer that is connected to your DAQ Device.  Find the Device in MAX, open a Test Panel, and create a Task where you configure the three (I'm assuming) A/D channels that you intend to use.  Set them as Differential or Single Ended, change the Max/Min voltages, the sample rate, number of points/read, and request Continuous sampling.  Push "Start" to check out the behavior, then make a Task with all these parameters.
When you now configure a Start Task function in your code, you can click on the Task input and wire a constant.  If you click the little down arrow in the Constant, it should show you the Tasks that MAX has configured (I hope you named your task something other than "Task 1") -- select it, it will set the channels, sampling rate, etc. for you.  Now all you need to do is put a DAQmx Read function inside a While loop, and you are Off to the Races.  [There may be a few more details to handle, but that's most of what you need.  You'll want, of course, to configure N Samples/N Channels ...].
(3,909 Views)
Ok, I did that, now how can i split the 2 processes, discharge and rest and still aquire during both cause using 2 time sequences in a while loop doesn t work?
Thanks!
(3,891 Views)
