NI CompactDAQ Multi Module Synchronization
I am testing a pump system and intend to enable plump with a digital driver and I need to record both analog and digital output from the unit
Using a 9178 USB compact DAQ chassy
Generating start pulse with NI-9476 digital driver
Acquiring data with NI-9422 Digital Input and NI-9205 Analog Input
Only the start needs to be synchronized.
How can this be done in DAQmx ?
(2,975 Views)
Hi Sir_N,
I believe you'll need to use DAQmx Trigger.vi or DAQmx Trigger Property Node.
There are some examples in NI Example Finder which you can refer to (Open LabVIEW >> Help >> Find Examples... >> In NI Example Finder, go to Search and search for keyword "trigger").
There are some links which are related to this as well:
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MiHSAU&l=en-US
Hope that helps
Warmest regards,
Lennard.C
Learning new things everyday...
(2,908 Views)
