NI Automotive Diagnostic Command Set
I want to comunicate with ECU via cRio using NI Automotive Diagnostic Command Set but encounter with below error..
im using NI-XNET 1.7 and NI9862 c series module...
also what different between NI Automotive Diagnostic Command Set and ECU Measurement and Callibration Toolkit?
please advice the best method how to read data from ECU (CAN BUS - OBD ll)
thank you
(2,916 Views)
You must install diagnostic command set to cRIO via MAX.
(2,909 Views)
How to install diagnostic command set via MAX. I have go through a forum. They said I need RIO I/O Scan to install diagnostic command set to cRIO. I already have this software but still unable to to install diagnostic command set to cRIO. Do you have other method to install diagnostic command set to cRIO?
Thank you.
(2,877 Views)
