NI 9481 Relay Output
Hi! I have just started working with the NIDAQ equipment. I am trying to switch realys on and off on the 9481 Relay Module. I can get the first channel to switch on and off but when i change the line number to 1 ( to get the second channel) nothing happens. I have attached the VI to show what I am trying to do. Rhys
(3,667 Views)
Didnt seem to add the attachment. Try again!
(3,665 Views)
Worked it out now!
(3,659 Views)
I am having the same problem you mentioned (only one channel can be switched and the others do not, even when changing the line #). You mentioned you figured it out, how?
or do you minde to share the code?
thanks
robarts
(3,595 Views)
Hi Robarts,
This is the solution that I worked for the problem.
Rhys
(3,575 Views)
This worked, thanks so much.
best
robarts
(3,569 Views)
