NI-9467 GPS Module Capabilities
I am looking into ways to have a time and position saved to the cvs file that is created in our VI that take many test point in aircraft flight test.
Right now I have to download the GPS data from the Garmin (or other gps avionics) and sync that data later with our cDAQ test data.
I cannot find documentation that says these modules send a time/position  data stream to the cDAQ other than this is a "The NI‑9467 provides accurate time synchronization for CompactRIO systems."
Can I used this module on my cDAQ and record to file the time/position data?
(2,097 Views)
Accepted by topic author Ezzell
No, the 9467 doesn't support the cDAQ platform. It only supports cRIO (expand the Read More section) via the FPGA interface
(2,081 Views)
Yes, Thank you.
I just found this https://www.ni.com/en/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
it list all compact DAQ modules and it concurs with you.
(2,054 Views)
