NI 9401 + cRIO 9082 speed measurement
Hello!
I want to measure a rotational signal with the NI9401 and cRIO 9082. For testing i am using a signal generator and it is connected to Mod5/DIO0. In the FPGA I want to measure the rising edges. (see attached picture) With them I would be able to calculate the rpm. But my code doesn't work: The counter counts up constantly even I have no signal generator connected. What is the problem?
Thank you in advance.
Best regards
Franz
(4,522 Views)
Here is a good design document that may help.
https://forums.ni.com/t5/Example-Code/Decoding-Tachometer-Signals-Using-CompactRIO-and-LabVIEW-FPGA/...
Figure 3 in the above white paper, uses the FPGA clock to determine the time between digital input events.  This is not a counter example, it simply uses the DIO to give the current state of the line.
Further down the white paper is a conversion VI to RPM.
Hope this helps.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(4,512 Views)
Hello!
Thank you for your answer. I have tried it and it works, but only with an analog signal. but i have an digital one... Now i found an interesting tutorial (Point 4): https://www.ni.com/en/shop/compactrio/do-more-with-labview-fpga---c-series-digital-modules-using-com...
There they wrote, that i can find the example in the example finder under Hardware Input and Output >> CompactRIO >> FPGA Fundamentals >> Counters >> Frequency Measurement >> Count and Period – cRIO.lvproj., but in my labview version (2015) I can't find this example. Do you have an idea where I can download it?
Franz
(4,473 Views)
Accepted by topic author franz94
Hi Franz,
I didnt find the examples in LabVIEW version 2013, but in 2012 you can find them. In general you could just download the version as a evaluation and get the examples. Since I found the examples in a VM youc an find the examples attached to this post.
Besides that most examples are a restructured in the newer LabVIEW versions but the general topics are still there.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,433 Views)
Hello!
Thank you very much - it works Smiley Very Happy
Now I'm able to measure the rotational speed.
best regards
Franz
(4,415 Views)
