Showing results forĀ
Search instead forĀ
Did you mean:Ā
NI 9361 Multiple Counter Channel Issue using DAQmx
Hi
I have a NI-9361 hooked up to a compact DAQ NI-9178 Chassis. the first two channels of the NI-9361 are used to measure frequency. The issue i am having is that when I build an exe and deploy it, it works I get the data i want.
However, if i lose power on the compact DAQ then i get no data whatsoever. There is nothing i can do to fix that other than make a daqmx change  in the code and rebuild the exe and deploy.
My initialization and read code is attached
Any ideas? Thanks
(3,172 Views)
Hi Abagha,
Just to clarify, is the issue only happening when the 9178 is powered on and off between tests?
(3,121 Views)
@TyVo wrote:
Hi Abagha,
Yes that is correct
(3,115 Views)
