NI 9264 continuous generation and output on demand - at the same time
using NI 9178 and module Ni-9264
I was updating code that worked fine on a PCI card, to be used on CDAQ and encountered errors.  Eventually its came to the following:
I copied the examples that ship with LabVIEW   (voltage-on demand output.vi )  and voltage-continuous output.vi, into a one vi to duplicate the error
I am writing code to output static (on demand) voltages on some channels and continuous generation on another channel using the NI-9178 and NI-9264 output module
Note that when  attached vi is run, and channels from NI-myDaq are selected (I have access to), no errors are reported and I can see the actual voltages outputted on an O'Scope.
but if I set my channels to come for the NI 9264, I get error about resources being used.  It looks like the module cannot continuous-output  and on demand output at the same time (of course using different channels)
the error reported:
Error -201105 occurred at on demand and continuous voltage out - issues.vi
Possible reason(s):
Resource requested by this task has already been reserved by a different task with conflicting settings.
Unreserve any other tasks using this device, or change their settings to be compatible with this task.
Task Name: _unnamedTask<30>
note currently I do not have actual access to the NI CDAQ module, but I am running with device simulation
note also that if the voltage-continuous output.vi, is run alone (disabling the (voltage-on demand output.vi  from running), no error is reported (on the NI-cDAQ module 9264)
If it is not possible to do that with the 9264 module, where is this  reported ?  (note that the CDAQ system is purchased and is at the customer's site)
(1,147 Views)
The "resource" that is reserved that you need is the sampling clock.  The myDAQ, an inexpensive general purpose DAQ device designed for engineering students, has 2 1-channel D/A systems, each capable of 200 kS/s.  The 9264 can do 16 channels simultaneously, at 25 kS/s.  So with the 9264, you have to sample both channels continuously.  Note that nothing says you have to save both channels -- you can split out the "occasional" channel and only save those data that you mean to save.  Alternatively, buy another 9264 (or another myDAQ?).
(1,111 Views)
