NI 9264 and NI cDAQ9178 triggering
All,
I am circling somewhat to my original question with this question: "Why won't this snippet of code wait for the trigger from the NI 9178 PFI 0 input?"
Thanks again for everyone's input!
-Heyou
Message 11 of 16
(1,419 Views)
Hi Heyou,
You are still using an Output task. Triggering should only work with an Input task. This may explain why it is not working correctly.
Michael B.
Message 12 of 16
(1,406 Views)
Michael,
Thank you for your patience with me. The reason I'm bemoaning  this point is that when I use DAQmx assist VI  I can produce a sine wave that the PFI 0 input functions as a trigger. What am I missing? The PFI triggering function is a selection with the assistant for NI 9264.  Any thoughts?
-Heyou
Message 13 of 16
(1,397 Views)
Hi Heyou,
Are you able to get DAQ Assistant to work with the trigger in your application?
Michael B.
Message 14 of 16
(1,385 Views)
Hey Michael,
No.     I am seeking to output my waveform from a *.csv file. My csv waveform will work with other code and the NI 9264 output. The last snippet I sent is with a version of the generated NI-DAQmx code modified as I thought it should be. But it isn't working.
-Heyou.
Message 15 of 16
(1,380 Views)
Accepted by topic author Heyou
This snippet works as intended. I must have been making it more difficult than it really was. Thanks for your help Michael and everyone! 🙂
Heyou
Message 16 of 16
(1,372 Views)
