NI 9239
Hi all,
I am measuring the battery voltage using NI 9239 and cRIO and my measurements are all proper. if suddenly disconnect the battery, the voltage is not suddenly droping to zero. if i try to connect the pull down resistor, there is no common terminal in the module.
can someone tell wot needs to be done??
Nanda
(2,970 Views)
Remember a Voltage difference of 0 V means that the connections are linked. If you measure the voltage with a multimeter you will get overload and not zero.
The 9239 is a differential mode DAQ device, so the inputs are floating. To get what you want connect the signals with a high value resistor (10 MOhm), be ware this draws a small current from the system.
Ton
Message Edited by TonP on 10-20-2008 03:15 PM
My LabVIEW Ideas
(2,956 Views)
