NI 9238 voltage (Unkown Bad Quality) in Distributed System Manager
I am trying to use the shared variable engine for a DAQ task. I am using LabVIEW 2020 SP1, NI MAX V20.5.0f0, NI Distributed System Manager V 20.0.0.
I set up NI-DAQmx Global Virtual Channel in NI MAX for a channel of the NI9238 module plugged into a cDAQ 9188, a channel of a NI9205 module plugged into the same cDAQ 9188, and the same in a simulated cDAQ Chassis:
With this set, I can use the run button in NI MAX to monitor the values of the channels. When I open NI Distributed System Manager and refresh, the NI 9205 and virtual NI 9205 both give voltage readings, but the NI 9238 and virtual counterpart both output an (Unkown Bad Quality) error as the value:
Has anyone ran into this issue when deploying shared variables?
Message 1 of 1
(1,036 Views)
