NI 9237 buffer overflow
I am using the NI 9237 to record pressure. According to pg 8 of the user manual the minimum sampling rate achievable is 1612 Hz (n=31). I need a very large buffer to store this data. Additionally, my program is slowed down to 1/30 of it's normal speed, making experiments take impossibly long.
How can I make the program run at a normal speed without buffer overflow?
Thanks.
(2,508 Views)
Increase the number of samples you acquire every iteration.
Don't write to the file in the same loop you are acquiring.  Pass it to a parallel loop with a producer/consumer architecture by way of a queue.
(2,482 Views)
