NI 9232 C series module with bridge pressure transducer
Is it possible to connect a bridge type pressure transducer to NI 9232 C Series module to measure pressure? and if yes will this module provide the required conditioning and excitation for bridge transducer?
(2,446 Views)
Hi wisjaf12,
I believe you found the answer to your question in your other post. Below is a link to that post for others interested in the answer to this question.
http://forums.ni.com/t5/LabVIEW/cDAQ-9184-with-NI9232-module-for-accelerometer-and-pressure/m-p/2249...
-Jake B.
(2,427 Views)
