02-02-2016 02:02 AM
Hello All,
I have chosen NI 9230 module to sense sound through piezo electric transducer output into it.
it has three input channels , i will use audio input to it , shall i use other two inputs to measure any analog signal.
i would like to use tilt sensor, its output will be 0-12v analog, when i go through the NI 9230 user manual, it says we use for 0-30v input, can i really use this for tilt sensor. kindly help me to clear my confusion.
thanks in advance
02-02-2016 02:27 AM
02-02-2016 02:39 AM
knowing nothing about your tilt sensor, I would say to just be mindful that the NI 9230 provides a 4mA excitation current on the + channel by default according to the data sheet. It says you can disable it for non-piezo sensors so it does sound like it could read any analog signal, within the given range of course.
Cheers,
bcl511
