NI 9219 with load cell
I am using the NI 9219 with a Futek Load Cell whose specifications are as follows:
Name Min Typ Max Unit
 Channel: 1
  Compensated Temperature 60  160F
  Excitation 1  20Vdc
  Hysteresis -.25  .25% of R.O.
  Input Resistance  744 Ohms nom.
  Insulation Resistance 500  Mohms @ 50 Vdc
  Nonlinearity -.25  .25% of R.O.
  Nonrepeatability -.05  .05% of R.O.
  Operating Temperature -60  200F
  Output Resistance  700 Ohms nom.
  Safe Overload   150% of R.O.
  Temperature Shift Span -.01  .01% of Load/F
  Temperature Shift Zero -.01  .01% of R.O./F
  Zero Balance -1  1% of R.O.
  Capacity   500lbs
  Rated Output  2 mV/V nom.
  Calibration Excitation  10 Vdc
I am getting a signal from my load cell which is great, but I was wondering how you can adjust the signal output to have minimal interference from noise, vibrations, etc. and how to program the load cell that it can be calibrated to zero (0) before any data is aquired?
Any help is greatly appreciated!
Yatsco
(3,813 Views)
Hello Yatsco,
Thank you for using NI forums.  One thing you will probably want to look into is using the filtering VI's in LabVIEW.  A low-pass filter can help to eliminate any high frequency noise from your measurement.  Also, take a look at the Field Wiring and Noise Considerations article for some more information on eliminating noise.  Lastly, this community example shows how you could calculate the DC offset and compensate for it before measuring your signal.  Please let me know if you have any additional questions concerning this application.
(3,797 Views)
