NI 9205 Multiple Configuration Measurement Issue
Hi, We are using NI 9205 AI card (NI c-DAQ 9178). We have 2 channels configured, 1 RSE and 1 Differential.
Common of card is connected to UUT ground. Following are the scenarios
1. When we create single task consisting both channels, we get correct reading in Max as well as LabVIEW software.
2. When we create separate task for Differential channel readings are correct
3. When we create separate task for RSE channel, reading saturates to -10.74 V value.
We are not able to figure out exact issue, is it wiring issue or something else.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(1,367 Views)
What are the channel numbers?
What are the signal voltages?
What is the sampling rate?
https://tmesystems.net/
(1,329 Views)
RSE Channel 05
Diiferential Channel 06
Sampling rate 15000 Samples per second
Both signals are voltages
Gaurav k
CLD Certified !!!!!
(1,320 Views)
