NI 9203 Compatible checks
i need suggestion can i use NI 9203 with Usb daq 9171??
(1,600 Views)
I don't see why not?  Is there a particular reason why you think you might not be able to?
See if you can add them into MAX as simulated devices if you don't have the hardware in hand to test directly.
(1,553 Views)
