NI 7350 encoder problem
I have 7350 PXI motion controller running under Labview 7.1. I am having problems reading encoders on my motors. I have 8 channels but only one works. I can switch wires to that channel and that way I tested that encoders are OK. Hooking up to other channels does not work. MAX shows zero counts or it varies +-1. Encoders are single ended quadrature encoders.
I think I set up everything the same way in MAX for each encoder.
1. How should I configure switches on SCB 68?
2. Are there any special steps I need to make in order to use it?
3. What about self calibration. Does it have anything to do with it?
4. Are there anyt switches/ fuses on 7350 that I should consider?
Message 1 of 8
(4,361 Views)
Hi Andy,
Is there a reason you are using a DAQ breakout board with a motion card?  I'm unsure if this could cause your issues, but perhaps.
Stephen Meserve
Message 2 of 8
(4,333 Views)
I can say that I inherited it that way. It was working fine in the past.  I guess you would suggest UMI? What would that give me?
The problem is not solved but somehow fixed. I used channels 1-4 and it works now. I have no idea why channels 2-3 don't.
Message 3 of 8
(4,325 Views)
Have channels 2 and 3 ever worked?  IT is possible it is a hardware issue.
Stephen Meserve
Message 4 of 8
(4,308 Views)
I know channel 3 was OK in the past.  I think you might me right but I am fairly new to those things so I put blame first on me.
Message 5 of 8
(4,300 Views)
If you're using the SCB-68, you can ensure that the switches are in Feedthrough mode (http://www.ni.com/pdf/manuals/371745c.pdf, page 5).
Also, can you check the pinouts on the cable itself (at the connection point when it goes into the motion board?).
Jeff | LabVIEW Software Engineer
Message 6 of 8
(4,271 Views)
I did set it up as feedthrough. The cable is original from NI. I checked the resistance between the ground and the voltage output on the motion card - it is very small like 20 ohms...
Message 7 of 8
(4,245 Views)
Hi Andy,
Which cable do you have?
Stephen Meserve
Message 8 of 8
(4,224 Views)
