NI 5761
Hi, look at the program does not work * Trigger level 2*. When I want to use two channels at the same time, the lower one does not respond to the threshold. I did similar to the top.
Message 1 of 8
(3,464 Views)
Looked at the images and getting started example of the 5761.  Not enough info on what you changed.
Does the Getting Started example work out of the box?  (that is, if anything, what works?)
What does you FPGA VI look like?  Could you post the project and VI files (as a zip)?
ALE Consultants
Message 2 of 8
(3,397 Views)
Please write your mail, I'll throw you the archives with the programs there
Message 3 of 8
(3,388 Views)
Can you upload here to the forum?
ALE Consultants
Message 4 of 8
(3,385 Views)
Forum cannot upload archives
Message 5 of 8
(3,382 Views)
Not sure I follow.  What is an archive file?  (.zip?)
See https://forums.ni.com/t5/Using-the-NI-Community/Posting-Basics-and-Tips/ta-p/3698594
ALE Consultants
Message 6 of 8
(3,372 Views)
it does not download the zip extension
Message 7 of 8
(3,360 Views)
Sorry, not sure what else to tell you.
ALE Consultants
Message 8 of 8
(3,357 Views)
