NI 2954 USRP Ethernet unidentified device
I am trying to connect the USRP 2954 to my computer using an SFP+ 1GBps adapter and a CAT5E cable.
Firstly i downloaded the drivers for the USRP, then I tried installing and reinstalling the drivers twice, I tried disabling the firewall, I set up the IP as required by the manual, static host IP of 192.168.10.1 and the default gateway being 192.168.10.2.
I tried accessing the device from NI max but nothing showed up, and also tried setting the speed&duplex on the network adapter to 1Gbps, i also tried pinging the IP of the device it did not work as well.
Also tested the cable and it works flawlessly on other devices. (Router to Host)
(412 Views)
If there is any advice regarding this subject or this specific hardware It would be greatly appreciated as I am still unable to solve the issue.
(362 Views)
