.NET reference gets lost in FGV
I have a problem in LabView 2020. It worked in the past but now it does not.
Version:   LabView 20.0f1
This running in one line works:
BUT: This does not work (any more):
So, if you use the .NET reference in one line, it works.
If you use .NET reference in a shift register of a FGV, it looses the reference. The Probe tells me then:
The reference has an ID, but this ID is not valid any more.
But I have not closed the .NET reference in the meantime.
It does not store the reference in FGV shift register between iterations.
VI Properties are standard:
Any idea?
Thanks and BR
Eugen
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(1,636 Views)
Do you see the reference tunnel on the right side of the case structure?  It is set to "default if unwired".  Check that the reference is wired through all your cases.
Bill
CLD
(Mid-Level minion.)
(1,616 Views)
OK, seems to run now.
I think it was my mistake.
Thank you!
Eugen Wiebe
Bernstein AG
(1,587 Views)
