.NET reference from TestStand
I’m trying to pass a .NET library reference from TS to Labview have created the VI with the different commands. Here the problems start because without putting the Constructor of the class it’s impossible to see the property node functions since no library is seen. If I try to use a select struct for switching between TS reference and the Constructor node the VI give an error since there is a double and different references. So my question is how can I pass a library reference from TestStand to Labview?
Best Regards,
Zuc
Message 1 of 1
(1,272 Views)
