.NET picturebox does not work in executable
Hi there,
I have build an application which uses a picturebox to display the image that an IDS camera is aqcuiring. When running the application in the dev environment everything work fine. However, when I run the executable all of the property nodes return error 1. Does anyone know why this is happening?
(2,265 Views)
The left picture shows the value of the picturebox reference in the developement environment. On the right I try to do the same thing in the executable, but nothing shows. Does this mean the executable cannot find the .NET framework?
(2,244 Views)
Without looking at your code I doubt anyone can give you any meaningful responses. In this case it's not even clean what the error is and where it's coming from.
___________________
Try to take over the world!
(2,238 Views)
Below you will see one of the processes of the program.
This process receives the picturebox reference. When I use the ToString() function on the picturebox in the executable it returns an empty string.
(2,227 Views)
Accepted by topic author Ongelofeloos
I think that 'Reset all values to default' is the culprit.
(2,223 Views)
