.NET class conflict
I use a .NET API with LabVIEW 7.1 to perform some operations.
Here a some interfaces that I have to use:
interface IReader;
interface IWriter;
interface IReaderWriter: IReader, IWriter;
interface IVirtualPipe: IReaderWriter;
A method of the .NET API return me an IVirtualPipe interface.
I want to use the method Write of this object(from the inheritance of IWriter)
My problem is that I cannot see this method when I try to use the "Invoke Node" on my object.
I try to use the "To More Generic Class" on my object to retrieve the IWriter interface whithout success=>I have a "Wire: Class conflict".
So, I have two questions:
1. Why I cannot see the Write method from the object ?
2. Why I cannot retrieve the IWriter interface ?
Than
k you for your help.
Sebastien
(3,324 Views)
SébastienF wrote in message news:<506500000008000000D6EB0000-1079395200000@exchange.ni.com>...
> Hi,
> interface IReader;
> interface IWriter;
> IWriter)
> Thank you for your help.
> Sebastien
I find a solution: use "Type cast" instead of "To More Generic Class"
But I don't understand why we cannot see the Write method of the upper interface...
Bye
Sebastien
(3,324 Views)
Which parameters did you use as target class and as reference for the function 'To More Generic Class'?
Is your solution to use the 'To More Specific Class' function?
Marc Larue
NIF
(3,324 Views)
Thanks for your response.
A .NET reference to IWriter
I tried this first because that seemed to me the good solution (more
logical):
IWriter
IReaderWriter
IVirtualPipe
but I cannot plug a IWriter .NET reference to the "Target class"
connector.
I have a "Wire: class conflict".
Since I can use 'Type cast', I use it. But I will prefer to use 'To
More Specific Class' (more object 🙂 )
If you have any idea ?
Is it normal to not have access to IWriter methods from IVirtualPipe ?
Sébastien
(3,324 Views)
The best would be for me to reproduce your problem.
Could you explain where to find the object that you use or to send it if you created it ?
regards,
Marc Larue
(3,324 Views)
