.NET Interop Assembly dll problems
I urgently seek help on the following questions:
1) I have used the Labview 2011 to compile a .net interop assembly dll which only has 1 vi. However, It generates a very long method with many parameters.
I have already deselect the unwanted parameters which i needed but the method is stil very long.
 method( out a, out b, out c, x, y , z , e, f, g, out h)
So is this normal? From examples i found.  The multiple methods are individual VI.  Is there any way to generate inidividual method to 1 vi?
2) I tried to use the generated dll with .NET 3.5 and referenced it successfully to my application.  However, on calling of the generated method, a tiny gui with the method name appeared.
The entire tiny gui froze and my application became not responding.  Whats the issue? is there some compatibility problem?
Previously I was using .Net 4.5 but i got VIClient error.  After changing framework to 3.5, this happened.
Any NI experts please give me some advice.
Thank you
Message 1 of 1
(2,667 Views)
