.NET Assembly use in LabVIEW
Caleb Said:
"My honest recommendation is to keep adding one component at a time back to the system and see if/where it breaks. Once we find the component, we can narrow down the cause and ascertain if it's due to a difference in how LabVIEW is interacting with your ADO, or if there is something else at play."
I agree. That is the plan for right now:
1. I will first build all of the modules that make up the Vital Signs project and see if there are any change after running the system that way for a day or so.
2. Install Visual Studio 2005 and build a few database projects with it, install them and run the setup for a few days.
3. Install Measurement Studio for the above compiler. test the system for stability as above.
4. Build a few projects with the compiler and measurement studio and see if the system is still stable
5. Figure out where to go if I get that far...
Bob
Message 11 of 12
(1,056 Views)
I sort of changed the order here. I've installed the applications built using Visual Studio 2005 and installed them using VS 2005 installer projects. The debug components are not installed. I have not installed the compiler. The only compiler on the test system is LabVIEW. As of today there has been no problems with the test system at all. I may have to ry to justify a copy of Visual Studio 2008 just to see if the compiler causes this problem. I need database access that is easier with Visual Studio than it is in LabVIEW. The NI plugins for database access are just strange and awkward.
Bob
Message 12 of 12
(1,035 Views)
