My computer empty in Application Builder
I just upgraded to LV 8.5 and activated the Application Builder for the first time. I have only one (large) VI to create the executable from. When in the Project Explorer/Build Specifications/Source files catagory, "My Computer" is greyed out. Therefore I cannot navigate anywhere to select a startup VI.
At first, the folder where I keep all my VIs are on the server/network drive for safe keeping. As a test, I copied the entire folder to my local hard drive and started over building the project with the same results.
Ideas anyone?
Gary
(2,877 Views)
You can only add VI's to the build that are added to the project.
(Regardless where the VI's are located. I do this from a netword and my
harddrives all the time).
Wiebe.
(2,871 Views)
Thanks!  That helped. I hadn't added the VI to the project.  Doing that, I was able to build the executable and the installer.
(2,866 Views)
