My application, after being application build is terminated by Windows
My application, EMXgroup, after being application build in Labview 6.1 is terminated by Windows 2000 with the following message, "EMXgroup.exe has generated errors and will be closed by Windows...", when the application Print Window... is selected in the run-time menu. Then run-time application Print Window... works fine when EMXgroup is run in the development system.
(2,390 Views)
I would recommend creating a service request with National Instruments to further discuss this issue.
(2,390 Views)
