Multiplot on Waveform chart with separate scae range for each channel
Hi All,
In my application I just like to plot all the incoming analog channels(about 10-12) values onto Waveform chart, just to see the trend. Each channels data have different scale ranges.
I done that as follows :
On Y Axis, I duplicated the original Amplitude (y axis scale name) to 'N' no. as per my requirement. Also I am able to change dynamically the minimum, maxmimum, increment value for each channel on y axis. At any point of time, Y axis have atmost any combination of 3-4 channels only. Depends on the selection of channel no., I made visible the relevant scale range, name etc.. sometimes these scales get overlapped. sometimes happens correctly.
Now I resolved scale overlapping problem by using the Active scale's Left & top property. But the active Plot area gone. I am not able to regain the actual plotting area by using any of the property like active plot's left, top, width & height property. Initially I designed a chart of width that should accommadate on the screen without the use of application's scroll bar itlsef. But after this problem occurred, it's
width got extended about 30%. Also is there any way to overcome the scale overlapping problem?
Can Anyone help me out on this issue?
Kousy
(3,427 Views)
Hi Kousy,
My suggestion will be, why not stack plots in your chart?
This way,  you can have a common x axis but an independent y axis for each of the plots.
think about it
Regards
Dev
(3,417 Views)
Which version of LabVIEW are you using? If you have LabVIEW 8, you could consider using a Mixed-Signal graph that can accomodate signals of different ranges, types (digital, analog, etc) all graphed along a common x-axis. It has separate viewing regions, scrollbars, etc. This could drastically reduce the amount of code used in your application, and provide a very professional user interface.
Take a look at this feature and others!
Jarrod S.
(3,409 Views)
Hmm, labview 8 seems to pack a lot of simplifiers.
But i gotta wait for a while till i can start doing on it  Smiley Wink
(3,384 Views)
I read ur reply Mr.Jarrod. but I am using LabView 7.1 version.
Mr. devchand, I dont know how to make stack plots. Is the width to the left of the actual plotting area is adjustable? I hope I should use transparent property of waveform chart to do stacking. but in vain. Sending out an example would be helpful for me to understand.
Kousy
(3,375 Views)
This attached example illustrates stack and overlay for charts
right click on the chart plot area and select stack plot/overlay plot option in the dropdown menu
Regards
Dev
(3,366 Views)
