Multiplot XY graph: bug in LabVIEW?
I first started a single plot XY graph with this array of points, where a point is a cluster that contains an x value and a y value. It worked fine until I wanted a multiplot XY graph.
According to the detailed help of the XY graph, it should accept an array of clusters of plots, where a plot is an array of points. A point is a cluster that contains an x value and a y value.
Whatever I try, it doesn't work. I included this example where I got a broken wire.
The example also shows the other option to display multiplot XY graph, and this works but then I have to redo a lot of coding.
Thanks for helping me out !
(3,109 Views)
Accepted by topic author PowertorUG
I found the solution and by way of thanks for the attention, please find both possible ways to display multiplots on the XY graph.
(3,091 Views)
