Multiplexer 4051 on Labview
I have a project to measure the voltage of 20 cells of a battery. I use an arduino uno but it has only 6 analog inputs. So, i use two analog multiplexer 4051 to extend the analog inputs and i want to display the results on LabView. My problem is that i don't know how to use the 4051 on Labview to display the 20 values of the cells. Thank you.
Message 1 of 9
(5,610 Views)
Do you have the 4051 mux hardware operaing?
Have you read this? Ardunio Playground Analog Multiplexer/Demultiplexer - 4051
You need to use three of the Arduio digital pins to address the 4051 and one pin to select direction (you could just tie this pin to +5 or Gnd as needed)
=== Engineer Ambiguously ===
Message 2 of 9
(5,599 Views)
Yes I read it. I simulated it with Proteus and I wrote the code on arduino and it works. Do I have to create a multiplexer on LabView ? Because I created one on Labview before but I didn't know how to connect the pin.
Message 3 of 9
(5,596 Views)
All you really need to do is address the 4051 with three digital pins and read the voltage passed through on an analog pin
Lets say you have the output 4051 (z) on analog pin 1 and are using D0,D1,D2 for addressing
If want to read the voltage on 4051 input y2
First write 0 to D0, 1 to D1 and 0 to D3
Then read the voltage on Analog pin1
I would create a typeDef and sub VI that would take care of all the addressing and read.
On closer inspection I see there is no direction pin on the 4051, the E pin is an enable low so just tie it to ground unless you need  to use more than one 4051 on the same analog pin of the Arduino
Message 4 of 9
(5,582 Views)
How can I read 8 voltages ? analogRead of the arduino on LabView had only one output voltage. Do i have to modify the subVi of the analogRead.vi ?
Message 5 of 9
(5,565 Views)
You read 8 voltages by setting the mux for 8 different patterns and taking a read each time. This is done inside a loop and you save each read In an array. Or, write your sketch to generate the 8 patterns and the analog read and return the array to LabVIEW. Your choice.
Message 6 of 9
(5,558 Views)
It sounds as though your electronic skills may be limited. Are you sure that your voltages from the battery never exceed the input ratings of the 4051?  It is a nice device but is not very robust when it comes to overvoltage! You could also damage your Arduino if you are not careful!
Lynn
Message 7 of 9
(5,551 Views)
I use an amplifier and a voltage divider to reduce the voltage. Thank you very much for the help 🙂
Message 8 of 9
(5,545 Views)
Do you understand what the 4051 chip is and does? Have you read the 4051 data sheet?
Think of it as an eight input  binary controled selector switch.
You select an input and measure that input with one analog pin.
Message 9 of 9
(5,508 Views)
