Multiplex Multiple Columns into One
This seems to be a pretty basic question but I am struggling to get it to work.
I want to take a Matrix (1), and convert it into another Matrix(2) where Matrix(2) will have column 1 that was created from the concatenation of column 1, followed by column 2 ... etc from Matrix (1).  As a reult Matrix(2) will have more elements per column but less columns than Matrix(1)
Essentially all it is, is multiplexing a few rows from Matrix(1) into a new column in Matrix (2).
Thank you.
Message 1 of 12
(5,570 Views)
Sounds like you want Resphape Array.
Message 2 of 12
(5,564 Views)
Do you have an actual example of inputs and what you expect for an output?  I could interpret your problem in many ways.
Message 3 of 12
(5,560 Views)
I have attached a screenshot of the set up I have so far. The output of the while loop will be column 1, 2 and I want to store that in chronological order in a single column of a new matrix.
Thank you.
Message 4 of 12
(5,551 Views)
I am actually even more confused about what you want.  How would you expect the bytes to be combined?
Message 5 of 12
(5,547 Views)
I have attached a paint picture of what I am trying to do, ignore what I said before, don't want any confusion.
Message 6 of 12
(5,544 Views)
I'm with RavensFan.  Looks like you just need to use Reshape Array.  You may need to transpose the array before and/or after the reshaping.
Message 7 of 12
(5,533 Views)
Accepted by topic author algoballer
Yes.  You do need a transpose array before reshaping.
First function Array Subset is to get down to the 3 columns.
Transpose 2D Array.
Array size and mulitply array elements to get total number of elements in Array.
Reshape Array
Message 8 of 12
(5,520 Views)
Thank you very much for your help! Works perfectly! If you don't mind explaining, why is it necessary to transpose the array, I would have never thought of that.
Message 9 of 12
(5,512 Views)
Because 2D arrays are stored with the rows in memory order and reshaping does not touch the memory order, just interprets the existing elements as a differently dimensioned array. You need to transpose to turn the columns into rows. Once it is a 1D array, there is no longer a row/column distinction.
Message 10 of 12
(5,485 Views)
