Multiple waveforms from an array
Im trying to plot multiple waveforms from an o/p array. Im gonna have "n" number of channels and the voltage values are stored in an array. I should be able to plot separate waveforms for each and every channel. Im trying to do this using waveform chart and array. I know im missing something and im just not able to figure out what im missing...
The VI is attached, you should be able to see the waveform array and the waveform chart in the VI...
I also tried writing the data to a file and then to plot the waveform by reading the data from the file...
Thank you,
(3,059 Views)
I made some little modifications...
I have the data in a text file...im gonna try plotting the values from the file...
(3,056 Views)
I made some more modifications...im able to select one channel form the list of channels and print the waveform for that channel...
I should extend it to multiple channels and multiple waveforms...
(3,052 Views)
Discussion moved to here
(3,020 Views)
