Multiple strings in a single case of a case structure
Hello, i have this problem:
I have a string and, based on whats written inside of it, a case structure executes the respective case. two of the cases are exactly the same, is there a way to make a single case answer to 2 separate strings? Or do i have to keep 2 identical cases one for each strings
(1,091 Views)
You can use same case with Multiple Input strings.
Use Case with Comma Separated Eg: (Init,Execute) for both input it will execute the same case.
(1,086 Views)
Hi dom,
did you read the LabVIEW help for the case structure? There's a link inside the help taking you to another page about "range of values"…
(1,079 Views)
