Multiple sample clocks
I am writing a program where inputs from multiple channels are accepted and the average of each channel is calculated. For this I wish to have multiple sampling rates for different channels, each of which will be configured by the user. How exactly can I do this?
In addition, is there any VI that keeps a track of the time of running of the VI, from the time the VI has started running to the time the user stops it?
PFA the program I have done so far.
Thanks 🙂
Dheeraj
Dheeraj Bharadwaj
IIT-Madras
(2,604 Views)
You are creating a task with certain value and pass it to the other "Create Task.vi" sequentially upto 4.
If you are doing like this your settings will change and finally you will get only the 4th vi's task.
If you are using single ADC for all the channels (Depends on the NI card) then you cannot change the sampling rate and the other settings but if you have different ADC's you can create seperate task and achieve what you expected.
If you are using a timed structure you can take the iteration duration and from that you can find the total time taken.
Good luck.
(2,599 Views)
