Multiple plots to xy graph
I am using an x-y graph with multiple plots. Plot 0 is my data, and plots 1,2,3,4 are created by two cursors each (0,1; 2,3; ...) with a plot line drawn between them. I tried to set the size and color of the plot lines using references and property nodes but I got an error in the property node. How can I do this programaticaly? I want to set up all the plots and cursors at the start of the program. I will be saving this setup information in USR's and .ini files unless there is an easier way.
Thanks.
PaulG.
7.1
PaulG.
Retired
(3,174 Views)
What kind of error do you get? Can you attach your code?
(3,154 Views)
1077 errors.
PaulG.
Retired
(3,148 Views)
PaulG. wrote:
... I tried to set the size and color of the plot lines using references and property nodes but I got an error [1077] in the property node. .... I want to set up all the plots and cursors at the start of the program.  ...
This is a guess, but one source of Error 1077 is trying to set properties of plots that don’t exist ... or of cursors that don’t yet exist.  It’s been discussed a few times in this forum (e.g. here).
Fading out. " ... J. Arthur Rank on gong."
(3,141 Views)
Thanks. I followed the thread you provided and it looks like the resolution to my problem.
PaulG.
Retired
(3,121 Views)
