Multiple plots on single Graph
can someone help me please !!!!!!!!!
My problem is to have in single graph a mutiple plots, where the X axis must be the real time and Y axis is value wich I enter manually. In another way the VI must read the value wich I give and plot it functions of the real time.
Thanks Smiley Wink
Message 1 of 9
(4,097 Views)
I'm not sure I got what you need.. there are good example VIs if you go to *Help" > "Find Examples..." and search for graph or multi-plot or whatever you need.
Here is a quick snippet, is it what you need ?
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 9
(4,095 Views)
Hi TiTou
Thank you for your help, but it's not what I exactly need because I want to have mutiple plots in the same graph and to have the real time in the X axis .
Best regards.
Message 3 of 9
(4,091 Views)
here is a chart with 2 plots.
for the X axis, you can set it up as you want by right clicking on the X-axis and chose "Formating".
Hope this helps
Epictetus
Antoine Chalons
Message 4 of 9
(4,087 Views)
Thank you again TiTou, this VI solve the problem of the multiple plots.
Can you help me to replace "add value" with the real time please ??? Smiley Happy  In anthoer way I want to have the graph wich unroll with the real time in the X axis and where I can have to control just the amplitude. Smiley Happy
Best Regards
Message 5 of 9
(4,081 Views)
Oh, ok... I first didn't understand what you meant by real time Axis... So correct me if I'm wrong, you want the X value to be the time at which you clicked "add value", right ?
If so, you'll have to replace the Waveform Chart with an XY Graph and every time you click take the time stamp+value add add it to each plot.
There are example in LabVIEW please have a lookt at these.
Epictetus
Antoine Chalons
Message 6 of 9
(4,072 Views)
Pas exactement, ce que je veux c'est que je n'aurai qu'à jouer sur les deux glissières pour changer les amplitudes des deux courbes et que sur l'axe des X le temps se déroulera en continue j'usqu'a ce que j'arrète le VI et ça peu importe le type de graph.
Et encore un grand merci pour votre aide. ( désolé pour la langue) Smiley Wink
Message 7 of 9
(4,069 Views)
Comme ca ?
Epictetus
Antoine Chalons
Message 8 of 9
(4,066 Views)
TOUT A FAIT   Merci beaucoup Smiley Happy vous m'avez été vraiment d'une grande aide, maintenant il me reste justeà afficher sur l'axe des X le temps et la date actuel car il met toujours le 01:00:00   01/01/1904  par défaut.
Encore Merci
Message 9 of 9
(4,062 Views)
